SSolderitch
I have a utility tag with 11 incandesent lamps (parking & clearence) which are fused on the trailer. I blow fuses until I get above 15/20 amps. Then everything is ok. I have no way to measure it, my fluke meter stops a 10A. I burned up the 7 pin to 6 pin round adapter because of the internal 20 gauge wire (rated for 7 1/2A). I rewired with a heavy cord with 7 pin connector. the wires range from 14 to 10 gauge (?) they are robust. Do the bulbs really draw that much? I heard 1/2A to 1A each = 11A at most?
Trailer has a full size battery for the winch
next problem: I blew the 20A fuse in the pdc for the brake lights when towing. Is the prodogy controller the problem? What does 5 stop lights & 4 electric brake magnets draw? Again I can't measure over 10A. Replaced the fuse & truck brake lights are ok. I am hooking up trailer for state inspection on thurs.
