question about COMP w/ strt pipe
Paint care, wax and clay
timeing set on ebay
i am rid of the cummins auto i had
but i missed the straight pipe sound quickly...
soooo i took off ONLY THE MUFFLER this time...
left on resonator... .
it is still missing something...
is it because the comp is off, and that is a timing enhancer?
so with out it, sounds less agressive?
No, it's because you sill have the resonator on which is still taking the sharp 'rasp' out of the exhaust noise.
Why don't you hook up the pump wire? Your 5spd clutch will hold it just fine if you can delay the fueling a bit (like to 10psi). The 6spd clutch won't, but the 5spd clutch will.
-Mike
-Mike
truthfuly i have to send my comp back to Edge to get a replacement to fit the 2002 ram.
and I am a little p. o. 'ed about wasting 35 dollars on a reducer for the 4 inch to 3 inch after the resonator. I didn't think it would take out the loudness, only the dreaded DRONE!
darn the luck
