Question about installing Bilsteins
DT Trackbar question
font sway bar size???
Installed my Bilsteins today (98 2500 2wd). When I removed the OEM front shocks, I found the upper bushings were plastic (nylon?). I went ahead & installed the new rubber bushings that came with the shocks, but I'm wondering if I should have used the plastic bushings instead.
Also, the Bilsteins have about an inch less downtravel than the OEM's did- will this hurt anything?
On my 98 I used all the bushings the bilstein box. Don't recall if they were different lenghts, but I do recall having a hell of a time trying to hold the shock up while attaching the lower bolts, man that gas sure applies some pressure.
I think I did mine with the tires still on.
When I did mine, it was easier to take the tire off and I left the plastic shipping strap on that held the shock squished down. I used the new bushings and haven't had any problems.
Originally posted by tpcdrafting
When I did mine... I left the plastic shipping strap on that held the shock squished down.
No shipping strap on mine. They were fully extended in the box. You WILL build muscle compressing them!
