Hi John,
The length you need will depend on a few variables. The height of the adapter you use for the delivery valve holder, how high it holds the dial indicator, the length of the pin on the dial indicator. Unless you have copied someones kit exactly, knowing the pin length will not guarantee a setup that works. It might be easiest for you to try your setup and measure the required length yourself.
Joe
