Chief USA
When accelerating and I have the go pedal to the floor I can hear a clicking or tapping noise I am guessing is from the engine. If I let up just a touch on the go pedal, the noise stops. Firewall it and it starts the noise again. It is not real loud but definitely detectable. The engine is bone stock and has about 11K on it. I initially thought the injection pump might be making this noise and checked the fuel pressure up to the pump with my Briar Hopper gauge and the pressure is 6 psi @ WOT in 5th gear minimum. 15 psi @ idle. Oil pressure stays over 40 psi and coolant temp at 190. I buy my fuel at the Flying J so it is fresh. Has anyone had this issue or is this normal noise and nothing to worry about? I have added diesel fuel additives (John Deere, Howes, & Power Service silver bottle) and it makes no difference in the noise. I am planning to get the tech at the Dodge dealer to go for a ride with me to check it out but I would like to have a good idea of what this could be if it is not normal. I am hoping maybe someone here has noticed this or had this issue before. Thanks for any help.
