Thoughts on being able to drop rail pressure from 21k to 8k at WO. Have dual feed rail without relief valve, mod cp3 pump, 90 horse injectors, and FASS 150. With smarty removed and TST on 6/6 should I be able to pull the rail that low? Once pressure comes back it jumps to 26k.
I have noticed that fuel pressure latley from Fass has been jumping all over the place. One secound it will be 15psi and then 2psi. Pump doesn't change sound. Bad FASS?
