question on sway bar help!!!!!!!!!!!!!!!!!!
NO BRAKES!!!! HELP!!!
engine performance
Please help i have a 99 3500 4x4 reg cab auto when i purchased it it did not have a sway bar on the rear so i got one from dodge mounts under the shock mounts to two small brackets on each side of the frame with two srtusts now the dilema. I installed a mag hytec rear cover now the bar hits and the directions say only 2wd need spacers the rear of the bar hits the diff cover has anybody ran into this before and does this swaybar sound like it is monuted right i think the cchrysler parts guy got me the wrong bar but that was a year ago nowplease help?????
99 24v auto 3500 4x4 reg cab 3. 55 axle,va cpc,275 injectors,k&n,rhino lining, tinted glass, tonnoue cover heavy duty trailer tow set up goose neck hitch draw tite brake setup,cb,cd player,catz back up lights,amsoil frnt to back,jre exhaust4 wire blue box, pressure lock,bd exhaust brake,JRE style transgo shift kit, a pro torqe extreme convertor, and a magtec trans cover and trans guage,JRE fuel line kit,upgraded fuel pump,braided fuel lines from lift to injector pump,reflashed ecm,power edge ez,fuel pressure guage,3 guage pillar,boost&pyro
I just installed a Mag-Hytec on my 01. 5 3500 4x4 with out using the spacer. It sounds like the earlier trucks need the swaybar spacer. I have the instructions for installing the spacer, E-mail me your fax# and I'll send them to you.
Terry
[This message has been edited by abledog (edited 01-04-2001). ]
Looked at mine, original cover, looks like about three inches between the cover and the sway bar at the bottom. bg
White 99 3500, QC, 3:55, auto. most options except leather, Line-X bed liner, fiberglass running boards Rancho 9000s, bug shield and window vents, black vented 5th wheel tailgate, 100 gal. aux. fuel tank.
