I have replaced the stock 4 inch spacers between the springs and the axle with 2 inch spacers so I can get enough clearance between the top of the truck box and the lower surface of the 5th wheel ('98 3500 4x4). I know others have done this also in some form or another. Have any of you noticed that there seems to be a slight increase in drive shaft type viabration with the change in the angle? I am considering changing the angle of the differential so that the front doesn't point up quite as much, but before doing anything I thought I would check to see if anyone else is having this problem and what, if anything, they did about it. For me, I wish you could order 4-wheel drive without adding all the height.
