welded up a stack box ...
then a big 'ol roll pan kinda bumper out of 1/4" with the hitch mounted flush, 120 lbs worth ...
now i wanna make a set of ladder bars that mount on the axle tube ...
has anyone got photos / advice
i was looking at curries 2 1/2 inch rebuildable johnny joints and a shackle the same length as the rear spring shackle mounted at the front so that the axle can move back and forth as the springs compress ... hopefully prevent frame cracking i've heard about with the ones that bolt solid to the bottom of the frame
i have a freind with a cnc machine that'll cut up to 3/4" plate so i can get creative with the ladder bars themselves ...
questions:
3/4" plate with "cummins" cut out aughta be plenty stout, right?
could i just weld the brackets to the axle tubes and just bolt the bar to those brackets ... do i need hiem joints at the axle if i've got those big high flex joints and shackles at the frame
anyone run anything like this on the street ... if so have you got any photos / ideas
hope to have 'em by indy
thanks
questions:
thanks
