I could use a little educating here. I hear alot about a trac bar I think I may have a problem with mine The symptom is a clunk in my steering wheel when turning to the left after a right doesnt always do it but is getting worse. . So while I was jig the dowel pin today which went really well I was checking front end stuff. I found that there is what I think to be the trac bar makes a clunk sound when I rotate it by hand this part is hooked to the pitman arm? Part off the bottom of the box. Am I on the right track here and if so what is the best replacement part for this is there a perm or more durable fix? thanks for the help and for those on the jig lists this set up is awesome I was done in no time very good system and equipment to work with Hats off to the creator or creators of this process Best regards Patrick
