Questioning the power of an EZ
Surging- cold transmission
This looks interesting
Originally posted by CUMINNTSTRKN
kev
did he shift? lay the 2 graphs over one another and see if there were any big chenges in the 2000rpm range.
jim
Yep he did shift, this test is showing from 20mph all the way up to 85mph.
Kev
Re: EZ
Originally posted by chuck3
I know a six speed HO will put out more HP than mine or something is drastically wrong.
Keep in mind though that even though this truck is a 6spd, it is an ETC, not an ETH, which explains why the HP rating isn't higher then what it is. Though I don't think it should be as low as what it is.
Kev
In response to Tom, my truck dynoed at 190 hp stock. With just the ez added and no boost elbow, I dynoed at 220 rwhp. That was also without the psychotty. I wanted too see what the box would do by itself. I couldn't use the elbow anyways. By the way, this was done on a mustang dyno. I'm happy with the seat of the pants power difference.
Ray
There was a thread on this when the EZ first came out. The extra fueling (depending on which setting) happened on the lower spectrum of the rpm band. I am thinking the 60 Hp addition was at 2000-2100 Rpms. ? By 2700 RPM's (or so) the fueling was back to stock levels and only the timing influence was felt. That is my memory of the description. Call the guys at Edge and ask for sure.
dynoed truck at cummins putten 250hp to the ground befofe the fan came on then 238 they said that was pretty good. stock@235 less 10%
