Have been following all the Vibration issues in the threads for a few months.
Was wondering if there is the same issue with 68RFE Transmission with the same Vibrations?
Read todays link about issues with the 68RFE not wanting to go into gear right away after startup,
while sitting over night. I usually start my vehicles and let them settle in for a minute of two before,
putting it in drive. I've been doing this for years and never had problems with any of my vehicles.
The issues with the Aisisn seems to be a combination of Bad tires, some suggest the frames are too
rigid and some drive shaft issues, with re-flashes used to try to help solve the problem also used.
Hope fully in the end all will be solved in the future.
The reason. Planning to by a Fifth Wheel in the next few years and do not want to be sitting around for a month,
in some camp ground. While Dodge is still trying figure out what to do next to correct the vibration issues in
the Aisin transmission with my new Ram? Will probably order the tires i want to be on my Ram to begin with anyway.
I do not see problems in using the 68rfe Transmission like before which was used before the introduction of the
Aisin Tansmission last year, in the 3500.
Would like your views on this matter,
Thank you for your replies,
Scott
Scott
