Originally posted by Bill Kondolay
Hey guys,
Please dont spend a lot of time on complex flow charts, let stick to the topic at hand. All that is required at this point in the thread is the pressure readings as that is the information relevant to what we were discussing.
We dont expect you guys to go to great lengths, the information we need you should have had when you did your baseline testing before you began your project.
Just fill in the blanks,
Apply pressure is ________________
Release pressure is ______________
Then we can carry on from there.
I am sure you guys want to keep this digestable for everyone to follow along and not want to confuse everything with a bunch of flow charts .
To be quite blunt this is an easy one, heck if the release pressure is 0 psi, there would be no clutch drag as the oil would move freely between the clutch plates.
Bill
Please tell me what you are after here. Pressure is a direct relation to volume flow. In this converter and any other converter oil is fed into the converter.
In fluid coupling mode, Oil volume is fed down the input shaft, between the piston and the cover then to the impeller/turbine section. When the oil passes through the clutch plates all the clutch plates are surrounded by the same oil, this means the clutch plates are not influenced by a pressure differential because they are all exposed to the same pressure. Any object in the pressurized vessel will not be influenced as long as the volume of oil is not allowed to escape to a lower pressure area. Loosing oil volume through a clutch plate (Piece of steel with friction bonded to it) would not be possible in my mind.
This is not a difficult theory to under stand. You said we are defying the laws of physics. Are we, or do we understand the laws of physics.
Earlier in the post D. Showan said “What I gathered from the posts from CCannon and Dramer is that on the release side there are multiple fiber and steel plates but that they are all exposed on all sides to the same fluid and pressure.
So with equal pressure (it wouldn't matter what the pressure is) the steels and fibers won't apply in any direction and are kept separated by the fluid film and would not wear excessively. ” ______
He explains it well, D. Showan is not a transmission man. I have a hard time believing you don’t understand the operation of our converter.
