if you are going to keep your truck forever buy better parts... ... ... .
well , where do i start, i replaced both hubs last yr, had one squealing on me, luckily both came off fine.
there are a too many posts that people have had nightmares in trying to get the hub and front shaft out. . front shaft off- frozen to the hub, the axle nut off- frozen to the shaft too and the hub off the knuckle- frozen toooo. sooooo when everything gets broken down, abit of anti sieze on hub nuts, abit of grease on front shaft where it goes through the hub for ease of later tear down.
not sure on the specs for deflection for the hub, if it an't squealing it should be ok, not sure if yours is rebuildable, mine is not, it is a whole unit,,,, if you can aford it go for a free spin kit. threads on this too.
-bushings- go for the poly ones, daystar is one manufacture. some make kits that have all of them.
Check the following;;;;
-shocks
-all bushings
-i believe adjustable ball joints are called for, seems people been having problems with them---go for non adjustable ones, check this article, i have moog on my ford never had a problem but my dodge is way heavier, buy the best.
Dodge Ram Suspension: Carli Upper Ball Joints w/ Moog
-steering dampener
-track bar and all assoc. sterring linkage
-ujoints---front half shafts and front 4x4 shaft, get the ones that have the grease fitting on the cups if it is on the body it is not a strong. if yu can get the shaft off take it too a good shop, they got all the tools and presses. posts on problems getting them off for the first time.
-brakes and assoc. stuff, it might be a good time to change the fluid, bake fluid absorbs moisture.
-front diff- fluid change
-tie-rods
-springs
i am not sure how far you want to go, i plan on keeping my truck forever, stuff that you can get off and take some where because they got the
RIGHT TOOLS for the job, tools are expensive. save your money diesl might go up again.
if you haven't change any diff or transfercase, transmision you might want too,, some poeple advise if the transmison is shifting ok than it is fine and you don't have to change it, but if that was the case the motor oil, more for gasers, would be ok too. the trans see heat just like oil and sometimes more if you tow or beat the crap out of it.
i hopes this helps for a start,
