I have an '01 with edge juice, fass 150, ats exhaust three piece, 4 in turbo back, afe... At a stop I start to spool up my turbo, and get on the throttle after x amount of boost is built up. My truck pretty much acts like it has no fuel, it will stutter like I am rodding the throttle full/none... My question is, does it do this because my injection pump is going bad? My stock injectors will not keep up with the amount of fuel needed for those parameters? Or is the fass fuel pump not supplying enough fuel. The higher the stage the worse it is. It also does the same thing in stock, but not nearly as noticable. fuel pressure never drops below 9psi. It only does this when I build boost before take off. If I just stomp on it without building boost, can't even notice. I have really been thinking it is just the stock injectors.
Another question I do want to get upgrade injectors and want the mach 4's. Is this too much with stock turbo? In the future I am planning on twins. Would it be best to wait for that big of injector until bigger turbo? If they would be too big, which ones would be best?
If anyone could help please. I would love to hear comments
