Yo Hoot
Mark the mating flanges and remove the bolts at the yoke.
Tap the flanges apart. Once you have the front part of the shaft disconnected, it's a good idea to tie wrap it to the frame to get it out of the way. No need to unbolt the transfer case side.
Mark the nut to the pinion. CAUTION... ... this only works if re-using the original nut. A new nut will not be identical to the old one with respect to where the threads start and total nut height.
You can also take a reading with a vernier.
Using a 32mm thin wall socket, remove the nut.
Pull the yoke.
Remove the old seal with a screwdriver. You can get behind the flange of the seal at the very outer edges and tap it out, going around and around.
Wipe the surfaces clean where the new seal goes. The new seal has sealing compound on it's outer surface
so the mating surface needs to be clean. Install the new seal. I used a wooden block. Try to slowly get it started
evenly and tap it around so it enters relatively even.
At this point it is advisable to put some thread sealant on the splines as they can be a leak point. They were originally gooped up from the factory.
Also since we are re-using the nut, it would be a good idea to use some blue loctite on the threads.
Install the yoke, the inside thick washer and the nut. Tighten it back to the original marks and depth.
Re-install the driveshaft.
The whole process took me a couple of hours but I don't have everything at my fingertips. Every stage I'm walking around looking for something. If I was to do this again and had everything I needed when I started it would probably only take a half hour total.
Pull the yoke.
