Not in this case. My TEPS coordinator was involved in every aspect of this and I saw him today, got the rest of the details.
Once the error was discovered Reman only wanted to authorize a crankshaft change. My guy refused and asked what damage the raw fuel did to the kits as the piston was down so far that fuel was spraying anywhere it wanted in there. He figured correctly that it washed down the walls.
Once he proposed that scenario Reman authorized a short block for a proper repair.
Then the talk turned to "How did this get through the line"?????
The Reman engines are test run and dialed in. This engine was hooked up in the chamber, exhaust is vented outside of course. Motor started, built oil pressure. Then they dial in the fuel for the selected horsepower. They got fuel enough for it to reach 600hp. No one could see the black cloud that had to have been hanging outside of the plant.
Rubber stamped it and shipped it out.
Now that we have it together it has to be driven to the Cat Dyno facility in Mass. to be re-calibrated because right now with the correct crank and the extreme fuel rate dialed into it we figure it is pushing 800hp at the very least.
Woo Hoo, don't let the customer drive it yet!!!!
Mike.
