I have had my rasp in for a year or so with out any issues you get so used to great fuel pressure you forget to keep a constant eye on the gauge. I was coming home the other day and noticed the pressure would drop to 5-6 psi under 1800rpms. I kept the pressure up and came strait home replaced the filter and the pressure was back to 11 psi at idle 16 0r so at 70mph. The filter only had 5500 miles on it it is fleet guard I am using a 2001 filter housing not the 99. I took the regulator out and shimmed the spring now I am at 15 psi at Idle but I can not remember if the pressure came up slowly after the truck starts or just jumped up I say slow about 5-7 sec. also when I romp the throttle hard the pressure dips 1-2 lbs then goes up . I think I am fine as even with the smarty on 8 ans the comp on 5 it never dips below 15 lbs. just curios if this is how your rasp reacts... Thanks George
