Yesterday I removed my radiator fan and clutch *** . from my truck. Just to get me through the winter I put a 16" fan on the front of the condencer and hooked it up to run anytime the A/C is on. I also plan on having a manual over ride inside the truck.
Here is what I have found so far... .
The truck is alot queiter first thing in the morning. It also responds faster at any throttle setting.
I am going to run like this until spring when I also have a 18" electric fan for the inside that will be hooked up to a thermostat as well as having a manual over ride inside the cab.
Right now here in Utah our highs are in the high 30s so I haven't been able to see if there will be a problem with heating up until spring. I do get up to temp faster also.
EAT'M UP
97 2500 Club 4X4 3. 54, Forrest Green/Driftwood, LSD 5 speed, & Psychotty Air System, TST #11, 370 HP injectors, timing at 16 deg. , 16CM2 housing, AFC spring kit, Geno's Exhaust Blanket, TST EGT gauge & 0-60 boost gauge in A Pillar, Cat-be-gone, 4" Dynomax Bullet muffler, Crome 4" turn down, AmsOil Through out, Geno's trans filter kit, AmsOil Bypass system, Lund Winter front, Leer Cab Level Shell Driftwood , 255/85R16, Dyno'd 342 HP pre injectors & turbo housing *NRA/USPSA member and proud of it*
EAT'M UP
