In the past there were many discussions about whether or not to put window screen in front of your radiator. Concerns with overheating vs preventing bug buildup that might be worse than the airflow reduction from a screen.
I always use window screen in front of my radiator. Last week I was towing my fifth wheel (around 14K as loaded for winter trip). I was in Nevada and towed up an 18 mile long grade that varied between 5% and 7% with 95 degree plus temperatures. I was using air conditioning. The engine temperature needle held at just about a needle width to the right of the 200. This is where it goes towing up any hill, even in the cold. So, even with the screen there was no apparent increase in engine heat.
Edited to correct my error, meant 200 degrees, not 210. Was just changing my oil when I noticed the center of the gauge is 200. My bad!
