Radio and clock reset
For you guys wanting a CAT filter kit.
What are symtoms of a bad FCA?
For the past week when I would leave the truck parked for over an hour, the radio would be switched to a. m. (was listening to f. m. when parked), and the clock radio would not be showing the correct time. Somehow losing power. Both batteries were replaced back in October of 2010. Any help would greatly be appreciated. Frank
It would help if you filled out your signature so we have some idea of what truck you have - the on-board systems changed a lot over the years. .
Look at the fuse panel at left end of dash(door has to be open to see it). Should be a fuse tagged IOD(ignition off drain). This powers the clock, radio memory etc. when ign. is off, may be blown. bg
Or may not be seated all the way.
Mike. :)
Sorry guys, I thought my signature is on. I own three 2003's and one 92', the problem is with one of my automatic 03'. How can I tell if my signature is on or off? I wiil check the under dash fuse tonight - truck is out on job site. Thanks
Try this. Go to pulldown menu at top of page, under Discussion Forums find User Control Panel and click on it, on left side of page find Edit Truck Profile and click on it, enter truck profile/profiles and click on Save Truck Profile. Should do it. bg
What you need to do is copy your profile , select edit your signature and put it in there.
If done correctly you will see it showing up at the bottom of all the posts you have already made.
I have never been able to make the profile show up.
Mike. :)
Looks good, I thought it would fill in the previous posts as well.
See what I know... ... :D
I do know if you edit it like I do for mileage changes, adding vehicles, etc. it will reflect the changes in any of my old posts.
Mike. :)
