Radio losing it's memory
Anyone installed this intercooler
Is there a way to get a message to Bob Wagner of MADDS
2012 Radio problems...
When I start my truck the radio loses it memory. The batteries were replaced because I thought, after 6 years, it was probably time and causing the problem. Well, it's still doing it.
Any ideas?
You are not giving much info to go by there, but I was having problems with my radio changing channels all by it's self. Also a 2012 with a 730N-RHR radio. I fixed it by updating the radio software. The fix involved purchasing new mapping software, that also comes with new radio system software. I haven't had any problems with the radio since the updated software was installed. Don't expect much of a change with the new mapping software, but everything does seem to work better. Its not cheap at $150 but it worked.
https://www.driveuconnect.com/support/software-update.html
The radio should be powered up at all times and actually then turned on via a BUS message. So it sounds like the BUS message may get corrupted on start up?
First a hard reset*, then an update, then dealer.
In this order.
*that doesn't mean disconnect the battery, it means push buttons in an order to set it back to factory.
Your radio is up to date...
Oh well...
And this was the first thing I checked.
Radio is the Uconnect 730N - RHR
