Count me in, chrome bezel white face. PM for info. Thanks, JR
Diesel Power said:custom... ... ..... i want pictures Oo. let us know. thanks
MMeier said:One little note about the install, think someone else may have said something similar, but here it goes. On the gauge harness, I would've liked to see some more length from the gauge end to where the dimmer control is and also where the sensor harness plugs in, anyone else thinking along these lines?
TWest said:It will reach a Pillar Mount. I did install the back light into the dimmer switch. No side effects at this time.
TWest said:Here"s Why.
One Rear Axle Temp Gage,One Oil temp Gage installed in the windshield Pod
One Trans Temp Gage & EGT gage Post Turbo Steering column Mount
One live Boost gage Pillar mount (I like My Handle)
One Fuel gage installed in the Dash
Pacbrake, High idle and fan override switches in dash with Pac idle switch. NOS bottom,Ramp switch,ATS commander,Brake commander,Lift switch. smoke bottom.
Muffler EGT gage (currently not in dash NO room)
E2 PDA with GPS.
With the PDA I can monitor up to 55 conditions and View up to 15. That"s Why No room left in truck,unless I close the cub-by hole than the cells/radios I carry would be on the floor.
its not to bad to see it. I modified the right side of the gage,so its angle to the left about 10*,if you look at the top of the gage you can see the angle adapter.
Diesel Power said:is it too short for a pillar mount?, or where do you have it going?![]()
