JStieger said:
I maxed out my SPA gauge with just injectors and TST. The high number recall was 27,000 psi. I don't remember if this was at WOT momentarily or if it occurred when I lifted off the throttle quickly.
Before the TST, I popped my relief valve late last summer when I was running the 03 Edge Juice (timing/duration/pressure) with injectors.
you are not maxing out the SPA you are maxing out the on-board factory (Bosch) rail pressure sender.
there are two problems with a 27,000 psi figure coming from a digital gauge. First, you don't know if you are reading a short, momentary spike or a sustained pressure. In particular, the peak detect is probably showing you the highest detected peak, not the highest sustained average. So it really isn't meaningful. There are very short spikes going on all the time in the rail, but those are not the ones you care about.
Second, 27,000 psi isn't really meaningful -- this figure is at or just a bit above the saturation point of the factory (bosch) sending unit from which the SPA receives its signal. In my tests I cannot read over 26,500, but that could be because I read the rail pressure signal with respect to signal ground at the sensor and not with respect to chassis ground in the cab. I found that the vehicle chassis is noisy and that I got slightly higher readings when using chassis ground. So that probably explains why the SPA reads a bit higher than I have been able to measure. There will also be some differences from truck to truck. my sender might saturate at a lower pressure than yours.
The Pricol gauge that I worked on has an input circuitry that snubs the short spikes to you see sustained pressures. it also brings in two wires from the engine compartment to avoid the noise inherant in the chassis ground.
so the bottom line is that when you read 27,000 with the peak recall, you don't know if actual pressure is higher than that (the sender is blind to pressures above approximately 26,500), and you dont' know if that pressure is sustained or just a digital spike. and if it is a spike you dont' know how short or long it is, or whether or not you should care.
