Well i dont own a 3rd gen Cummins but i do have the same fuel injection system as you guys do (dmax) and was wondering if you guys are having any problems with the high performance side of the fuel system. On the duramax side of things were having rail pressure issues, buddies truck is dropping to 8,000psi full throttle with big injectors and big tunes. Is anyone working on a larger pump and what have you guys done on the supply side of things and what kinds of results did you have? I have a supply pump on my pulling truck that i would like to put on a dmax and see what kind of rail pressure gains i could achieve if any. I have a regulator and could supply anywhere from 1-85psi to the high pressure pump. I'm thinking that i should bypass the EDU and supply it fuel with some other system at like 5psi just to keep it cool. Whats the max psi anyone supplied to their pump? Or does anyone know what the safe level is? Thanks, Matt
