Rail Pressure
Dodge Ram Hybrid Electric Vehicle (HEV) Goes Into Production
Help with the edges
I have been wondering what the max safe rail pressure is? I searched the forums and found one that had a conflict between 23200(I think) and 27000. are either of these true?
These are my reading off my outlook
IN PARK
At Idle: it varies between 5,750 and 6,050 PSI
At 2000 RPM it is about 16,500
At 2500RPM it is about 20,500
IN DRIVE
At WOT I can hit a max of 23,167 PSI
now this is with a power pup only
At what PSI does the relief valve pop
Are these pressures about the same as you all are seeing or are they higher??
Just want to make sure nothing is wrong.
Thanks
Daniel Rice
I believe the truck makes about 23000psi stock and with a box like the EZ or other pressure box can raise it up to 27000+psi I think just above this pressure is where people have had problems with their relief spring. I've only heard of a couple of cases over the last year or so of relief spring damage.
drice said:
so My power pup really doesn't raise rail pressure at all on the performance setting great news
Thanks for the info...
I believe in inssue 47, DLeno reported at about 26500 the relief valve
starts bypassing fuel back to the tank.
I liking the Bully Dog Pup more and more. Waiting to see info
on the latest from Quadzilla before buying.
Carl
