has anyone taken a rail relief apart yet, i took one apart tonight, only to find it had debrees under the seat, it was leaking at only 2200 psi, i was going to shim the spring, but i dont know what the spring length is on a new spring, and my porta power only goes to 16000 psi, i will put it back on the truck and see how it runs, if anything it should get me back and forth to work for a few days, till the new one shows up... i also have a cp3 for an 06 taken apart in every piece possible without breaking anything, these pumps are simple, radial piston, 3 pistons with a lobe on the drive shaft... ... Oo.
