Ram to Build Most Capable Trucks Ever
EDGE Products Settles Lawsuit with EPA
TDRadmin
Staff Member
[RAW]
<p align="left">#ad
<br/><br/>&#8226; Ram 3500 Heavy Duty&#8217;s maximum trailer weight of 30,000 pounds far surpasses closest competitor&#8217;s 23,100-pound max<br/><br/>&#8226; 850 lb.-ft. Cummins Turbo Diesel is tops for torque<br/><br/>&#8226; 37,600-pound Gross Combined Weight Rating leads all heavy-duty pickups<br/><br/>&#8226; Ram 2500 leads all ¾-ton pickups<br/><br/>&#8226; Ram Chassis Cab trucks also deliver best-in-class towing <br/><br/>In the quest to build the most capable trucks available, Ram officially released class-leading towing and weight ratings for its 2013 line of Ram Heavy Duty pickups and Chassis Cab trucks. <br/><br/>The Ram 3500 Heavy Duty pickup will claim a 30,000-pound trailer capacity thanks to a new class-exclusive 50,000 pounds-per-square-inch, high-strength steel frame, improved transfer case, higher-load transmission, an upgraded 6.7-liter Cummins Turbo Diesel engine with a best-in-class 850 lb.-ft. of torque and other significant driveline upgrades. <br/><br/>Ram&#8217;s closest competitor is limited to a 23,100-pound maximum trailer. <br/><br/>"We built the new 2013 Ram Heavy Duty to be the undisputed Heavy Duty &#8216;King of the Road.&#8217; These new rigs deliver on the number one key attribute most critical to these customers: uncompromising capability,&#8221; said Fred Diaz, President and CEO &#8212; Ram Truck Brand and Chrysler de Mexico, Chrysler Group LLC. &#8220;Towing capability, reliability and engine performance are ranked first through third, respectively, with HD customers. The 2013 Ram Heavy Duty trucks unequivocally deliver all those things, as well as a very low total cost of ownership.&#8221; <br/><br/>The Ram 3500&#8217;s Gross Combined Weight Rating (GCWR) -- which is defined by the maximum combined weight of the truck, payload and trailer -- has been raised to 37,600 pounds, which again far surpasses the closest competitor&#8217;s 30,500-pound GCWR. <br/><br/>Ram has increased the capability in its other truck models as well. <br/><br/>For 2013, the Ram 2500 will also benefit from increased towing and GCWR. At 18,350 and 25,000, Ram 2500&#8217;s towing and GCW ratings are also best among ¾-ton pickups. <br/><br/>Ram Chassis Cab trucks also deliver maximum capability with best-in-class towing and GCWR figures 29,600 pounds and 37,500 pounds, respectively (5500 model). <br/><br/>Ram Heavy Duty adds a number of new features for 2013, including a factory-integrated fifth-wheel and gooseneck hitch mount, a 17,000-pound Class V hitch with 1,800 pounds of tongue weight, class-exclusive electronic stability control (ESC) for dual-rear-wheels and a new Center High-Mounted Stop Light (CHMSL) &#8211;positioned camera, the first of its kind in the heavy-duty pickup category, to provide a full view of the bed for easier hook-up of fifth-wheel or gooseneck trailers as well as monitoring cargo. <br/><br/>For 2013, all Ram Heavy Duty diesels benefit from an all-new cooling system. A high-efficiency fan, dual radiators, dual transmission coolers and low-slung charge air cooler afford 25 percent more heat-rejection capacity. Lower operating temperatures deliver improved performance, durability and lower operating costs. Cummins Turbo Diesel-equipped Ram trucks also provide best-in-class 15,000-mile oil change intervals. <br/><br/>Ram is also introducing an industry-exclusive Ram Active Air intake system. When the intake system senses extreme heat, it draws cooler air from the front of the vehicle &#8211; a function that also engages at high altitudes for superior throttle response in low oxygen environments. When conditions are wet from snow, ice or water-fording, the system pulls air from an under-hood inlet, clear from snow packing and water. <br/><br/>Also among the upgrades for 2013, Ram Heavy Duty front drive shafts and U-joints are sized larger to align with the truck&#8217;s new Gross Vehicle Weight Rating (GVWR) and Gross Combination Weight Rating (GCWR).<br/><br/>To handle the best-in-class towing and payload capability of the new Ram Heavy Duty, a new front and rear suspension system with advanced geometry builds upon the chassis improvements and greatly improves overall roll stiffness. An advanced three-link front suspension on the Ram 3500 is necessary for the vehicle&#8217;s higher GVWR and for use with heavy front loads, including snow plows. Additionally, a newly designed Hotchkiss leaf spring rear suspension on the Ram 3500 offers improved ride and handling while delivering higher towing and payload capability. </p>[/RAW]
