Last night I installed the Adjustable Ramifier, I really like the in cab adjustability over my EZ. The only concern I have is that the EGT's are taking off...
With the EZ I could just kiss 1300 on a 0-108mph blast, I duplicated the run with the ramifier turned all the way up this morning I hit 1400 very quickly (probably about 80-90mph) and backed out before it went any higher...
Are others seeing these temps with thier Ramifiers? The truck is entirely stock except for a box and EGT gauge... Stock A/F and exhaust... the air filter only has about 250 miles on it.
I planned on dyno'ing this on saturday but I am not sure the temps will allow a full run...
I have an extra "edge boost elbow" for the truck, I was thinking of installing that, but I don't know if this is going to help enough...
I know that the box is making more power (ie. fuel+power= more heat) but I am not sure I could even run up around the 70hp mark without excessive heat...
Not bashing the box by any means, there is definatley more power there but if I can't get the EGT's down a little then it won't be usable power for very long...
I will give them a call today and see what they say, but I wanted to see if others have gotten the same results.
Is the new Quadzilla box also causing these temps??? (please be honest)
Truck specs: 04 305/555 48re, EGT probe (pre turbo) in #3 area of manifold.
Thanks in advance,
Dave
Thanks in advance,
Dave
