my 06 5.9 has again developed a random no start condition. the first time this happened was right after I bought it (used) never did start and since I was out of town I had the local dealer assess it, said it was a bad starter, wanted $1100 for a starter plus labor!! I said push it out and Ill change it on your parking lot and they found an aftermarket starter and did it for ~300 out the door. 18 months later it occasionally wont start, in each case it is turn the key and nothing, no clicks no nothing, if the key is cycled some random number of times though it will start, usually it takes a few cycles but occasionally it takes several minutes. I have it to the same dealerfor the airbag recall and tell them about the no start issue, they investigate and tell me i need a starter but since its only been 18 months and they warranty all work for 3 years (I thought it was 5 years) they will replace it free. Oh BTW it needs an update to the PCM. OK so half a day but just out of pocket lunch I leave with a new starter (I think) airbag recall done and a current PCM. Couple weeks ago the same no start condition rears its head. Very occasionally it takes numerous key cycles to start. I call the dealer they find my repair record and tell me it was a starter software upgrade and not a new starter last time not that it matters because it was 37 months ago and the warranty is good for 3 years so its outside the warranty period.
a) Should a starter have a 1-3 year life? my 82 Jeep hasnt had a new starter in a decade or more, of course it only has 150k miles on it.
b) is there a software routine for the starter? Seems unneccessary but ....
c) better or upgraded starter to look for if I need to put in a new one ?
thanks all
thanks all
