Random tie down ?
Fan motor on 2003
Upgrade power steering pump
Looking for some help to find the correct bolt to attach the in bed tie downs. There are four locations to attach to with 2 "bolts" or "screws" but I can't seem to find the correct size/pitch.
My truck didn't come with the tie downs and would like to install some. Ive been to the local Ace to try and match but nothing seemed to thread with ease. I realize the holes might have some junk in them, but I don't want to force anything in if its wrong.
The closest thing I have found that might work is 5/16 - 18 machine screws. Let me know if someone can check.
Thanks in advance.
If there is a threaded hole in the bed it will definitely be metric, there haven't been any inch size fasteners on the Rams since about 98. I would check mine but it had sprayed in liner. bg
I had given up for a while it seemed like it should be metric when I was testing but nothing fit. Its good to know it will be metric. Going to the store soon I think, although it just started snowing again....
Thanks in advance.
Here's the Dodge part numbers with and without the bed liner for the hardware, tie-downs and bolts/screws.
BRACKET, Cargo Tie Down
55276782AA 2 Right
55276783AA 2 Left
TIE DOWN, Cargo
55276344AB 4 Without Bedliner
55276735AB 4 With Bedliner
06506356AA 8 SCREW, M8-1.25 (This part number is for the factory oval head bolt/screw in the factory tie down the bolt/screw in the bed is the same size just a hex head)
