Ranges for gauges
Looking to Buy; Any good Dealers West?
Rhino or other spray on Diamond?
I am going to purchase a SRT A pilar and would like an EGT/Boost gauge. My truck has not been BOMBed and probably will not be as I do not have a need for additional power (yet).
Will the Westac be good enough or should I get the HO version.
Thanks
Stock truck will see 22-25 psi boost max. Stock turbo can support 35-40 psi max if you decide to add a box.
-Scott
I installed an autometer with the srt 10 a pillar-- very nice setup.
Gauge range is 0-35. When I twist it in fourth or fifth the boost slams to 32lbs then drops back to about 29 lbs as I reach 3k RPM. Stock and staying there. Avg MPG 16. 4/ 17. 2-- 4500 on the clock. Overhead is off appox. 1. 3 mpg (low)
Paying 1. 54/9 in S. C.
JAH
