Jetpilot said:If you retorque the head you also need to check valve lash.
If you remove the crankcase breather and look inside you will see the pump gear. Line the timing mark on the pump gear to 12 O'clock and adjust Intake 1-2-4 and Exhaust 1-3-5. Then rotate the engine until the the timing mark is at 6 O'clock and adjust Intake3-5-6 and Exhaust 2-4-6.
Normally most guys set the Intakes to 0. 010 and Exhausts to 0. 020.
Hope this helps... .
Doug
jwilliams3 said:I would follow the Cummins spec (torque+90*) for resetting the head bolts.
Torquing to a number like 120 can over stretch the used bolts.
You might not ever get a click wrench to work with these style bolts.
Jetpilot said:When a head is retorqued the bolts need to be broken loose one at a time and retorqued to the proper specification.
Doug
Todd T said:Doug's Dead on! line torqueing or sequencing is fine for this.
