I'm helping a cousin to setup some digital gauges that normally connect to an ODB-II port. His swap is a 24v ISB from a 98 Dodge into a 79 Ford F250. The PCM was not swapped. I understand OBD-II codes can be read directly from the ECM.
Was speed information collected by the ECM or the PCM? What would be the best way to collect speed information to send through the ODB-II port to the digital gauges / data acquisition setup?
Thanks,
Chris
Thanks,
Chris
