alexanderJ
I've never noticed this before but I'm getting weird readings when checking transmission fluid level. I just serviced my transmission and after refilling with fluid and getting the truck up to operating temps, I'm getting a different fluid level on each side of the dipstick.
One side of the dip stick is showing the fluid about halfway between "add" and "max". The other side is showing the level about 1/2" below "add". I can rotate the dipstick 180 degrees and get the same reading.
The reading that is showing low level actually looks like a cleaner reading, with a very definite straight line at the top of the fluid level. Is this normal, and which reading is the more accurate?
