We often recklessly toss around numbers and percentages of power loss thru trannies, autos vs manual - 5 and 6 speed - but in point of fact, with the newer and heavier manuals, how much percentage difference IS there, really?
Sure, in passenger vehicles and their more lightly built manuals, the difference might be greater - but take a look at the sheer MASS of a 6 speed NV5600 or 4500, and imagine the power required to spin all those gears, as well as the heavier flywheel, clutch and pressure plate...
Is there REALLY as much difference as we have thought? Ken at Ken Imler's performance diesel specifies 25-30% power loss even thru a manual transmission such as ours - past percentage figures usually ran around 15% or so loss for manual trannies, 20% or so for auto trannies, but we now have larger and heavier manual AND auto trannies with OD - what do you fellas think?
I suppose a comparison based upon dyno readings, stock, auto vs manual would provide a clue. my own truck with the Comp and boost elbow added, Comp switched off, made an indicated 204 HP at the rear wheels and 437 ft lbs torque - but that's misleading, since max boost pressure was well above stock even with the Comp switched off... That compares with the factory rating of 245 hp and 505 torque at the flywheel...
These 5 and 6 speed trannies are certainly NOT lightweights!
