RealTrack GPS Installes w\Pics
c/d cleaner good for nav also ?
Removing OEM Steering Stabilizer Shock
RealTrack GPS Installed w\Pics
Here are some pictures of my hidden vehicle tracking GPS installed and the install process. I had to use one fuse that was always hot and another fuse that was only hot when the ignition was keyed.
I used the battery's ground location for the GPS. I had to lengthen all the wires on the GPS to make them reach the fuse box. I drilled small hole in the corner of the fuse box for access.
There was an extra plug in the firewall I was able to cut a hole in for running the wires. It's best to just pull the plug out of the firewall, make the hole, and pull the wires through, and reinstall the plug. Thank God the plug is designed to install from the drivers compartment not the engine side.
The antenna is magnetically stuck to a bracket under the dash near the circular looking vent near the base of the A-pillar.
