Rear ABS Sensor
Rear ABS Sensor
New transmission
On my 91. 5, the rear ABS sensor (the one on the top of the diff) was smashed off. The wire going to it was also mangled.
I got a new sensor and rear harness for it, installed the sensor, and tried to plug in the wire...
The top end of the harness for it (near the fuel tank) showed evidence of a previous short. The new harness would not plug in. I splices the new harnes directly into the wireing that it would normally plug into and the bloody ABS light still won't go out.
I'm guessing that the ABS computer might be NFG from the damage to the ABS sensor / shorting of the harness.
I'm wondering if you can put the ABS computer into diagnostic mode (assuming it isn't NFG) and then I could do 2 things:
- Reset the computer so the light goes off.
- Trouble shoot any other problems.
I need to get this thing inspected for insurance, so for now I have removed the bulbs from the dash (Brake and ABS).
91. 5 CTD 4X4, 5" Stacks, Tweaked Pump, 33" Boots
Try resetting the fault lamp by tempotrarily disconecting the battery. If this does not work you will need to look at the manual for help.
Neil
Neil Copeman 92 D250,LE,limited slip, 16cm turbo housing, Isspro gauges, factory tach option, Lear cap, DC crankdown tire carrier
Hadley air horns, Stealhorse leather seats, e-mail (home): bombedcummins@sympatico. ca
