Little help. I need to positively ID my rear axle for a disk brake conversion. In particular, the vendor is asking is the axle a 5500 or 6200lb unit. Don't have the truck with me, he tells me a sticker is on the glove box door with details. Called wife, she looks, no sticker. Apparently the studs are different. Problem he describes is with another customer who bough the kit for a 93, and found that the studs (1/2") would not fit in the hubs. Both the head and the knurled area are larger than the relief area on the back of the hub and the thru hole (respectively). If I followed him correctly, the 5500 axle is OK, but the 6200 has the larger head/knurled shaft area on the stud. Solution is simple enough, but just need to positively identify if I fall into the larger stud situation. Without looking, my guess is the axle is a 6200.
Thanks all
Pat
Thanks all
Pat
