I'm getting ready to change my rear axle lube over to full synthetic, and wondered about two things; do you need to put the additive in for the limited slip clutches and do you still change out the lube at the specified intervals? If you do the same change out, it seems like it would get pretty expensive. I plan on towing a 5th wheel on a long trip, and I understand the synthetic is the only lube to use; is it that much better than 85-140? Thanks
