Rear axle
RPM and speed for 4:10s
Need info on Amsoil Bypass System
Owners manual states Dana models 80 and 70 rear axles are delivered from factory with SAE 90. On next page it states multipurpose gear oils meeting specs API GL-5 are recommended for all axles. Does not specify what weight. Any suggestions on what to use? also what is the capacity of the NV-4500?
1999 3500,5 spd,3:54,Red,Gear Venders ,Fiberglass Running boards, Bed Liner.
Ralph,
For normal driving, buy hypoid gear oil meeting API GL-5 or MIL- L-2105C specifications, SAE 80W-90 viscosity. The trailer towing section in my owner's manual states that you may also use SAE 75W-140 synthetic gear lubricant if you use your truck to pull a trailer for a significant number of miles. And, just to be sure you have a wide choice, we are informed that Dana 70 and Dana 80 axles come from the factory with SAE 90W oil. With this wide range to choose from, I am using Amsoil Series 2000, 100% synthetic, SAE 75W-90 gear lube, which meets GL-5 specifications.
You pay your money and you take your choice.
Loren
2000 Quad Cab, 4x4, short bed, six-speed: U. S. Gear exhaust brake, MileMarker Select Drive viscous coupling, Velvet-Ride spring shackles, Painless Wiring circuit box, Optima yellow-top batteries, Super-Glide 5th wheel hitch, Reese folding ball gooseneck hitch, Drawtite front hitch receiver, Tekonsha Sentinel brake controller, Westin nerf bars, Clarion sound system
1995 Standard Cab, 4x4, long bed, automatic: Firestone Ride-Rite air springs, torque converter lock-up switch, 4" cat-back exhaust, Reese 20K 5th wheel hitch, Reese gooseneck hitch, Hayes Micro Control trailer brake controller, 100 gallon bed-mounted fuel tank with 12 volt electric pump & fill nozzle, Swiss Cap fiberglass cap
