Clarification
I didn't say that our bearings "need" to be swaped out every 100k. They "may" go forever. What I posted is...
Or to give my advise another way...
If it's a "wear" item or better yet, a "critical" wear item,
and there's been a reasonable amount of mileage on it,
and it doesn't cost not much to replace,
and it's relatively easy to replace,
then why not replace it?
It may cost much more time and money if you wait, because it may take out other tihings with it when it goes.
Driver Side Bearings (Preventive Maintenance):
Passinger Side Bearings (Seized-up):
Which one of these is not like the other?
Again, "It will be MUCH cheaper and safer to do them on YOUR time and place". IMO, PM schedule replacement is always better than the alternative with it's associated collateral damage.
For $60 and 2 hours (listening to Pink Floyd in the shade of my garage), I will include Rear Bearing Replacement in my PM schedule. And, because this is such a small expense, I will be doing it around 100k.
Maybe I just need another reason to spend some time touching my truck? I enjoy it.
To each his own.
- Ben
fj40charles said:... I just don't buy the argument that you need to swap the bearing out every 100K miles unless you're always towing something real heavy.
Ben Rumson said:... My advise to all is to replace your rear axle bearing on your preventive maintenance schedule (every 80K to 100K - depending on how hard you haul) and DON'T wait till they go out on their own. It will be MUCH cheaper and safer to do them on YOUR time and place.
- $30 (2 bearing sets and an oil seal)
- 1 hour
- $80 (2 bearing sets, an oil seal AND a new adjusting nut and holding pin)
- 6 hours
- The truck broke down away from home (I was fortunate that I wasn't on the open road hauling a load)
- I had to risk serious damage to the axle when torching the seized bearing out. How much is a new axle anyway?
To each his own.
- Ben
