My e-brake is officially worthless. my rear shoes are so loose that i can put the e-brake pedal all the way to the floor, and theres a lot of tension on that pedal cause the cables are tight, buts the shoes are so loose i can grab the tread and push/pull the truck very easily. which is a big pain with a manual, cause i dont want to always be sittin in the truck with my foot on the brake pedal if the things runnin, besides i want to perserve my rotors and pads up front with the help of the rear.
heres my question:
I was lookin in the FSM and seen that it appears you need a special tool to release the star wheel?? i though you just had to turn the star wheel untill your tires wouldnt turn at all, then back the wheel of 5-6 clicks?? do i need a special tool? i can udjust them from the openings in the back of the drums correct? thanks
heres my question:
