Rear brake hose
Long term storage question
Will a Cap from a 1998 fit on a 2003
Just an FYI and see if anyone else had this. I had to do a panic stop to avoid power lines and snapping telephone pole during hurricane Irene. The wires did get the truck but just scratches and nobody hurt. Anyway I blew out the rear brake line that goes from the frame to the rear diff. It blew apart at the metal fitting by the frame where the rubber hose connects to the hard line running to the front of the truck. When I went to repair it tonight, the entire fitting up by the frame was disentegrated and it fell apart when I went to unscrew the hardline from what was left of the fitting. I just thank God because 2 weeks prior to that I did a 4000 mile trek towing a 10,000 pound camper.
Nick
Holy *****, Just reading this took 30 days off my life. You might want to replace the other side while you're fixing it.
Unfortunatley last night, everything thing I took a wrench to broke off.
I went to take the rear caliper lines off the center block, they were froze and started to twist (I had soaked them in pb blaster. So I figured instead of trying to loosen the fitting, I would take the block off the rear, disconnect the driver caliper end end and spin the whole line. Well, the bolt that holds that caliper hose bracket snapped. Whos dumb idea was it to thread the spring perch and put a bolt in it.
Then I went to take the rear diff vent bolt out to replace the bad hose and that bolt snapped. I managed to free the block from the hose. But then I twisted the hell out of the passenger line to the rear caliper. So I just decided I'd replace all of them.
Well, turns out. The brake hose from frame to rear and the one from the rear to the driver rear wheel are available aftermarket. The one from the rear to the passenger caliper is dealer item only. I'm planning on just sectioning in a new piece. The line itself did not rot, just the fitting on the end was seized to the line. I have a bubble flare kit.
Also, what's left of the fitting is frozen into the bracket up next to the fuel tank.
So I have a bunch of work and cursing to do to something that should have been a simple fix and is a mess. Also something I don't think should have rotted out already. I'm pretty disappointed.
Not sure what I'll do about the broken rear diff vent bolt. I'm afraid to try and screw the remains out of the diff.
