1998. 5 Dodge 2500 4x4 NV4500 5 Speed Long Bed Stock Equipped
Gentlemen:
Now that I have finished replacing the rear drum brakes and rear hub seal for my truck, I have a few questions about the installation (These are questions that require experience for which I have little. ):
First: The "feel" of the brake pedal and stopping: The truck stops fine. I think I notice the rear brakes actually doing their job since the truck definitely feels different upon application of the brakes. No noises or odd sounds, not that I would hear them over the sound of the engine. My question is of the brake pedal. I bled the brakes (all four wheels) and the brake pedal is firm and stays firm before starting the engine. Upon starting the engine, the pedal is somewhat soft and the pedal will fade but the truck stops fine without pumping the brakes. The pedal will move to the floor if pushed hard enough. Is this normal?? (A brake man that I know says that this is normal since people are now paying attention to their brakes and pushing them for all they are worth. ) Still, what should the feel of the pedal be? I just can't remember what the brakes felt like when the truck was new.
Second: The rear hub rotation--I followed Dodge's FSM instructions and torqued the nut to 120 ft. lbs. then backed the nut off 1/8". The hub rotated by hand but I noticed a slight resistance upon turning, not a free spinning hub. Is this the correct feel of the rear hub? Usually with bearing type hubs, you tighten until you feel the resistance and then back the nut off a tiny bit until it spins freely. What is the correct procedure?
Thank you in advance.
M. Young
Fair Oaks, CA
Gentlemen:
M. Young
Fair Oaks, CA
