Brake System Bleed Procedures
Reference Information
For others bleeding their brakes the Dodge Service Manual recommends a few points:
1) Use brake fluid meeting SAE J1703-F or DOT 3. Fresh, clean fluid from a sealed container only.
2) Do not pump the brake pedal at any time while bleeding. Air in the system will be compressed into small bubbles that are distributed throughout the hydraulic system. This will make additional bleeding necessary.
3) Do not allow the master cylinder to run out of fluid.
4) If calipers or wheel cylinders were overhauled, open all caliper and wheel cylinder bleed screws. Close each bleed screw as fluid starts to drip from it. Watch the master cylinder to maintain the fluid level as well. (I did not follow this instruction. )
5) Attach one end of a bleed hose to bleed screw and insert other end into a glass container partially filled with brake fluid. Keep end of bleed hose is immersed in the fluid.
6) Open the bleeder screw at the wheel you are working on and have a helper press down the brake pedal. Once the pedal is down, close the bleeder screw. Repeat bleeding unit fluid stream is clear and free of bubbles. Move on to next wheel in this order: Right rear, left rear, right front and left front.
These instructions are contained on page "Brakes 5-15" of the 1998 Dodge Service Manual.
Regards,
M. Young
P. S. Mr. HHuntitall: When you announced that you had a fleet of similar Dodge trucks, I have to pay attention to your suggestions. Thank you for checking out your trucks and the differences present. The devil is always in the details with these trucks since manufacturers tend to change perfectly good systems for no apparent reason--at least to me.
Regards,
M. Young
