I have a 99 with a EGR front brakes and rear pads and cylinders. Since I have installed the rear pads the drivers side started to squeek bad, I also put on new drums from advanced auto, cheap inports. The worked good for a few miles then it started to squeek. Also if I am on wet pavement, especially first thing after I start up in the morning the drivers side will lock up with the littlest push of the pedal. I have also replaced the cylinder with a new one and it diden't make a differene. I have also sanded down the pads and it stops for a few miles then will squeek again. Any advice would help.
