Well since 6th gear ratio is so tall in the new trans I would go for 4. 10's and enjoy the benefit it would give in getting the weight moving.
From what I read it appears the final drive ratio of 4. 10's with a new 6 speed auto is the same as my 4 speed auto with 3. 73's and it is plenty tall, cruises easily at 70.
I gotta jump in here too. .
Gonna be ordering a new one to replace my 05 work truck with 130k... I`m thinkin of going the other direction and ordering 3. 42's. I dont tow anything big, maybe a small uhaul trailer for equipment, once a year. But I do carry around a good bit of stuff in my truck, usually ending up around 9k gvw. With all the miles I do, I gotta get every bit of mileage out of this. .
Anyone have a 4x4 6sp auto and 3. 42s?
-j
If your going to run loaded all the time, then a 4:10 gear is perfect, if your going to run it unloaded more than loaded, get the 3:73 gear. One of the benefits of 6 gears is to run at a lower RPM than the older 4sp trany's and still deliver the proper power bands through the gears. A 3:73 is great compromise from the older 3:55 vrs 4:10. 3:55 gears are a bit tall for the higher GVWR these new trucks (3rd & 4th gen) have and 4:10 is too high for normal driving. Both of my trucks have the 3:73 but they are manual trans, and the part time pulling heavy, only effects me when driving slow loaded on small inclines.I'll be ordreing a 2010 3500 laramie drw, 6- speed auto. i' ll be hauling a 3000#lance slide-on camper and towing a 3000# boat. Am confused about the best all around rear axle ratio? truck will be4wd. thanks. .
They don't, I think the focus is not wanting to run the engine at such a low rpm that efficiency falls short.Why does everybody want these things reved up so high?
Seems right to me, pic taken with my 3500 C&C on the way home from Kansas, look at RPM and my signature. FWIW my 2500 is the same with a 5. 9 and same rear ratio, look at signature for my truck info.Cummins recommendation for maximum efficiency with the 6. 7 is around 2150 rpm. Based on that number the automatic with 4. 10 gear ratio keeps you closer to that at average cruising speeds than the 3. 73 and 3. 42 ratios
IMO it should still be available though. You can get that combo on a 3500 C&C. If someone regularly towed heavy for work and wanted to run a taller tire + have a pick-up bed it would be nice.So yes with the standard transmission you may not want to go with a 4. 10 gear ratio. That is probably why you can't get the 4. 10 with the standard trans.
That is why I mentioned signature, it is in the sweet spot that you mentioned, although it is a manual, it is running at the average speed of an interstate in the RPM range Cummins recommends.It appears you have the standard transmission. I was speaking of the 6 speed automatic. The standards don't have the double overdrive like the autos. and 6th in the standard is around 0. 71, I think. So yes with the standard transmission you may not want to go with a 4. 10 gear ratio. That is probably why you can't get the 4. 10 with the standard trans.
Unless your planning on towing at over 65 mph, go with the 4:10. 1 with out a doubt. Based on your lash up the 4:10. 1's will keep the motor in the sweet spot while towing in sixth.
Mac![]()
With the auto and 3. 42 gears you're only at 1690RPM at 75mph! You'd have to go at least 85 to get into the ideal RPM for MPG, and by then you're going too fast anyway. . . not much point in getting this combo unless you plan to go 80-90 most of the timeWMoroni said:I looked at 3500 dually 4x4 0n the lot today with 3. 42s and the auto transmission. Why does everybody want these things reved up so high?
