2nd Gen Non-Engine/Transmission Rear disk brake pad removal
What is the trick to remove the rear pads. I have it apart but I can't seem to figure it out. Any help would be appreciated. I have disk brakes in the rear as well.
Thanks,
Dwight
Once you get the caliper pins out and pry the caliper out, the pads should come right out. There is a set of clips at the ends that hold them in, but not tight. Make sure you lube the caliper pins well when you reassemble it.
