Rear Door latch replacement.
part number for the trailer connector
Rotors
OK sportsfans, it appears I need to replace my left rear door latch. I see that a company named Doorman seems to be the prominent manufacture out there. I am also assuming MoPar has an equivalent. Does any one have a accurate model/part number. I also understand that the pin configuration is key to the conversation. Tanks
Are you sure it's the latch? The wiring harness is known to go bad in the 3rd gen's. Mine went a month after I got my 03 this past spring. I had no window, lock, or audio. Found a brand new OEM harness on eBay for a little over $200. Installation was pretty easy.
This pin out should help you test.
CAV CIRCUIT FUNCTION
1 G77 20VT/OR LEFT REAR DOOR AJAR SWITCH SENSE
2 Z75 20BK GROUND
3 Y201 18TN/OR DOOR UNLOCK DRIVER LEFT REAR
4 Y157 18TN/PK DOOR LOCK DRIVER LEFT DOORS
